10 Feb 2015 at 08:45 #1 psychas psychas Soldato Joined 12 Jun 2007 Posts 8,756 Location Ireland as per title does Samsung Data Migration Software work fine when you want to clone Os drive ?
10 Feb 2015 at 09:16 #2 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham yes
10 Feb 2015 at 09:19 #3 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,429 yeah, should work fine. I haven't used it as I did a clean install of the OS but it should work without any issues.
10 Feb 2015 at 10:29 #4 psychas psychas Soldato OP Joined 12 Jun 2007 Posts 8,756 Location Ireland thank you
10 Feb 2015 at 10:30 #5 Harl0 Harl0 Associate Joined 23 Oct 2012 Posts 213 Same process as ghosting so should take everything!
10 Feb 2015 at 13:59 #6 psychas psychas Soldato OP Joined 12 Jun 2007 Posts 8,756 Location Ireland so i don;t need to back up my desktop icon shortcuts should be there?
10 Feb 2015 at 14:01 #7 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,429 the software will transfer everything from 1 drive to the other
10 Feb 2015 at 15:40 #8 psychas psychas Soldato OP Joined 12 Jun 2007 Posts 8,756 Location Ireland ok thanks good to hear
10 Feb 2015 at 18:11 #9 pumaz pumaz Soldato Joined 7 Oct 2003 Posts 5,693 Location Nottingham is it possible to clone a 1TB SSD woth only 60GB used by windows and apps to a 120GB SSD? Both Samsungs.
10 Feb 2015 at 18:37 #10 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,429 pumaz said: is it possible to clone a 1TB SSD woth only 60GB used by windows and apps to a 120GB SSD? Both Samsungs. Click to expand... yeah, should be fine as its only cloning the space that has been used and not the size of the drive
10 Feb 2015 at 19:37 #11 pumaz pumaz Soldato Joined 7 Oct 2003 Posts 5,693 Location Nottingham Thanks, its been a while since i cloned a drive but remember it being a pain if the destination is smaller than the source.
11 Feb 2015 at 17:19 #12 pumaz pumaz Soldato Joined 7 Oct 2003 Posts 5,693 Location Nottingham Worked a treat, Samsung Migration software is really very good
11 Feb 2015 at 19:01 #13 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,429 glad that its all working fine and was successful!
