- 21 Sep 2012
This has got me motivated to start over clocking mine tonight![]()
i wanna see dem numbers
Another poster in here can go slightly further than me, so the challenge is set can you beat his
Another poster in here can go slightly further than me, so the challenge is set can you beat his![]()
Damn I'm jealous of these clocks at stock voltages! I need +50 voltage on my Tri-X 290 to get 1150/1500. Strangely, 1150/1450 is unstable on the same volts, and 1150/1550 gets a worse score than 1150/1500.
This is my score at standard.
4960K @ 4.6Ghz.
Standard clock (1030/1250)
FPS: 66.8
Score: 2795
Lets see where we go from here!
Which means nothing in the grand scheme of things as their stock voltage maybe higher to start with.
4960K @ 4.6Ghz.
FPS: 66.8
Score: 2795
4960K @ 4.6Ghz.
FPS: 66.8
Score: 2795
I think your right, im sure my pcs+ was +13 on the voltage out of the box, overclocking will very between cards the tri x I have at the mo is the highest clocking 290 ive had, I can get that up to 1200/1500
Is that valley 1 or heaven 4 on the wrong settings?
Yup, it's to do with the ASIC Quality and all that business.
Right so this just happened..
Ignore the How to overclock tab open, i couldn't remember what settings i needed on.
Again, stock clocks 1030/1250.
And it's higher..
Help?
And it's higher..
Help?
GPU-Z is saying my first 290x has an ASIC quality of 77.8%. I got it on release, so it was a reference card and was probably a decent one, since i didn't have to budge the voltage until i started to push 1150 on the core. Its under water atm and i bench with it at 1300,1600 (up to 1625 depending on the bench) with a hefty +250mv. Got a lightening a little later with a higher ASIC quality but it didnt seem to clock as well and stock voltage under load was higher.
I don't understand Unique Heaven benches on anything but 1080p, what score are you getting on a 1080p run?
should be 1080p wrong mode![]()
