Moving into a house which has been empty for 6-9 months.
16 Nov 2002
The Moon
What would be wise things to do when we get the keys next week?
I was thinking giving the heating a blast on full and also opening all windows to get some fresh air in the house and circulate air through it a bit.
I'll also be making a note of what the leccy and gas meter say but aside from the bills side of things, are there any practical things you would recommend doing when you first get the keys?
Unlock the door, step through door, close door, put keys down, put kettle on, make tea, sit down with tea, drink tea.
was the water turned off over the winter? Empty houses, no heating and water systems can equal big leaks so it will definitely worth checking that all out.
Other than getting to know where you gas/water shut off valves are, electric board/fuses etc there's not much else to it.
It'll be a little dusty so a good clean and enjoy it :)
I'm not sure if the water has been off in all honesty. I know the heating has been on a couple of times as the vendor has put it on when we've viewed it last.
If it has a cold water storage cistern I'd give it a check, make sure a squirrel or whatever hasn't been doing backstroke in it and died.
Open every window and door for a couple of hours no matter how cold it is then close them up and wack the heating on.
Find the stopcock
Label the trip switches in the consumer unit
Change all the door locks, you don't know who has an old key.
Take a bottle of wine round to your neighbours to say hello, ask about any local issues.
Check under the patio flags for bodies.
Dump caravan on front yard.
Park vans in front of neighbours houses.
Tie up large dogs in back yard.
Install large speakers, open windows and play same track over and over again.
Instead of thinking things in your head, yell them all out at the top of your voice.
Get many tattoos, shave head, answer door with no clothes on.
Get rid of the sold/let signs ASAP. These notify the local thieves that the property is occupied = new stuff = potential place to burgle. Install an alarm & change the locks too, you never know who else has keys to your new place.
