1) Am I right in saying that Hyperspace is for moving between systems whereas Supercruise is for getting around inside systems quickly? If so, I noticed while Supercruising to a station that my speed kept increasing but seemingly started decreasing on it's own without any input from me? Why would it do this?
I believe this is due to the effect of stellar bodies / mass in your vicinity effecting your frame drive's ability to "fold" space, hence slower travel.
2) What is the best method to drop out of Supercruise as near (but safely) to your destination? (I seem to be unable to slow down sufficiently when the "Slow Down" warning pops up and always end up going past!)
Alternatively lock onto the destination and supercruise to it at 100% throttle. Once your target destination time in your HUD counts down to 7 seconds reduce throttle to 75% and you can keep the destination ahead of you and you will auto-throttle to a safe speed and distance to drop out of supercruise at your required site. (You can wait until 6 seconds tbh if you fancy saving a bit of time).
Your third question.... not a clue
