Morning all, coming out of lurking to ask for some tyre reccomendations.
Car is a Peugeot 508 estate which takes 235/45/18 rubber. Have been using continental sportcontact 3s on it which are a great tyre but I'm only getting about 10k out of them on the rears - a bit more on the front. I've done nearly 30k in the car in the last year so it's getting a bit boring changing them so often!
I totally understand that hard wearing means harder rubber which means less grip. It's also a big heavy estate that's often got lots of heavy equipment in the boot so its going to be wearing tyres pretty quickly. It had a hunter 4 wheel alignment last week (front camber was a bit out, rear was all in spec) and tyre pressure is checked every couple of weeks.
Ignoring budget tyres completely, the price range for the tyres available which Id actually consider using (the Kumho is probably the cheapest Id entertain) is between £130 and £160 per corner, so price isn't really a concern. I just want something decent, safe, quiet and that might last a bit longer than the contis. Looking at the Michelin Primacy 3 or the Goodyear F1 AS2 at the moment. I did have a pair of P-zero Neros on the front at one point but they didn't seem any better for lifespan and were a bit torque-steery. Any thoughts?
Cheers
Cheers
