- 12 Nov 2014
- Westgate On Sea, Kent
How does the INTEL processor compare to AMD in GENERAL.
(1. Oldest question in the book: No real definite answer only personal views by users - which is what i need to here)
(Also each CPU has different graphics capabilities and also memory communication and control capabilities/utilities)
2. Is there a recommended benchmark/review website that takes into account overclocking capabilities.
now i been trying to purchase a new gaming rig on a Smaller than i would like budget and the processors make's a big difference.
3. So do i go for a intel i5 4690k stock 3.5ghz - unknown full o/c capability
(which i would like to know and what MB you used with it to obtain that O/C value ??)
OR
4. Is there a cheaper AMD CPU that would be equal too or better in CPU capabilities including overclocking capabilities.
4.a. Also how do the two different CPU's INTEL AND AMD effect the graphics card capabilities. Integrated HD 4600 Graphics / ?? / EG. , Other AMD or INTEL Specific item.
AMD Radeon™ RAMDisk , AMD Radeon™ Solid State Drives (SSD) , AMD Radeon™ Memory, max memory speeds and how it communicates with memory
4.b. Is CPU shared memory a Advantage/disadvantage and built in CPU graphics Controller, what possible bottleneck of GPU problems may occur with AMD or with INTEL , are there any particular graphics advantages with AMD or INTEL,what integrated graphics capabilities and effects on installed cards are there using AMD or INTEL. GEFORCE for INTEL and RADEON for AMD
4.c Also AMD have a range of there own memory and utilities. Does this help or does intel have similar advantages.
i looked at AMD FX-8350 4.0Ghz stock , 4 x 2 logical core - 8 core. that shows on a single benchmarks website that its faster than a Intel i5 4690K , 3.5Ghz stock, 4 cores.
However it also states that the AMD could only be overclocked by 0.2 Ghz and the INTEL by 0.4 Ghz. Not much of a improvement on either and sure that more can be obtained.
As i got 0.5 Ghz out of a old INTEL DUEL CORE E6700 3.2Ghz (Stock) got it to 3.7Ghz no special alterations just manual change of FSB. And a slightly better than stock fan a arctic cooler non stock.
If You use any of these CPU's Please advise O/C Capabilities..
5. what have you found to be the best stable Ghz on each of these two CPU's.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-540-IN INTEL CPU :£199.99
http://www.overclockers.co.uk/showproduct.php?prodid=CP-336-AM AMD CPU :£149.99
OR
