How's the battery life on Lollipop?
Encouraging stuff. As I said before if the next batch of phones disappoint then I will definitely be looking to get a Note 4.
Has the UI changed quite drastically?
Fast charging has improved with Lollipop?
I'd be hugely surprised it it did, it's a hardware level system. An android update is near enough impossible to have improved it on a functional level.
damm it has removed root!
It usually does.
If your rooted, you usually go the whole hog and use a custom recovery and flash rooted roms.
Flashed mine tonight, snappy isn't the word!![]()
I flashed my Note 4, does anyone else notice a red light come on the back when they lay it down?
Turn the screen off and cover the HRM on the back, does it light up?
can you put the German 5.01 Rom on a carrier branded Note 4?
