Haha, well from the "small" so to speak 510 drip tips that I own, the kf4 drip tips the widest bored out one iv got all the way through that is compaired to a regular 510 tip.
I like straight through tips, not ones that are narrower at the base then expand out, like say the dome style tip I linked in post above.
I dno, theres sommat about the wide tips I don't like, I mean iv got a POM tip for my mutation x2, actual pom fitting, not pom then 510. don't really like it to be honest.
maybe Ill like it once I go lower than 0.2 ohms, but its a overkill, not enough vapour coming out yet to need that size.
I like the feeling when the vapour goes straight through rather than narrow at one end then wider at another or vice versa.
Also im a sucker for my stainless steel tips, don't like plastic feels nasty
Is that pom 510 tip wider at the top than the bottom though? would be just like that dome style tip im guessing, I don't know I just cant gel with it.
But, I was thinking of the plume veil tip, its wide bore but again its not straight through like what I like, but it does look trick
https://www.fasttech.com/product/1806701
that tip looks 6.5mm one end, and around 10mm other, I guess I could get it and drill the bottom out as much as it can go though so its more of a smooth bore straight through
like now, iv just tried the pom mutation x v2 tip, its not warm and smooth flowing into my mouth like the smooth straight through feeling I get from the kayfun v4 tip.
the ball styled tip, its same feeling as the pom mxv2 tip.
like, I like the feeling of the small bored out drip tips that are 5mm wide straight through but there not nearly wide enough to cool the vape at 0.2ohm, but the kayfun v4 tip is 6.5mm wide all the way through, it does the job well.
the ball styled tip is 6.5mm one end, 11mm other end, the mxv2 pom is 11mm one end, 18mm the other. they both feel exactly the same to me the vapour to mouth wise, it doesn't feel like its being directed smoothly into the mouth
