** Water Cooling Sale**
Would love to give the Primochill hard tubing a go in my system - but you are always out of stock on clear tubing, both the 4 packs and singles, and have been for a long time. I would buy some discounted revolver fittings now - ready, but is there any point with no tubing available.:(
Mark
Ps the bending tube inserts are also oos as well
Mark
I agree.
I'd love grab a bunch of the Primochill Acrylic tubes if they're in stock as well.
TwsT, do you think you'll be able to give a pre-order discount for the clear acrylic tubes? http://www.overclockers.co.uk/showproduct.php?prodid=WC-132-PM&groupid=962&catid=2800&subcat=2802
Hey Twst,
Can you have a look at my basket - will this all work together ok? If so can you discount at all? and I will buy now.
Mark
there's always monsoon tubing
same size
I think that's a little bit risky.
From what I heard, Primochill tubes were manufactured according to imperial measurements whereas Monsoon are manufactured according to metric measurements.
Of course it'll be really nice if I can heard some official words on the compatibility :D
4 packs are due first week of march sadly discount is not upto me I did the fitting discount becuase that one was a slow mover we haven't sold any for over a month so a bit of movement won't hurt the clear stuff we sell 30 units + a month and are havign a hard time with supply
primochill's slightly bigger
so might have a problem in primochill fittings I suppose.
Think that answers my question above -re basket, a no go then.:(
Mark
So after the above post by Twst - best to wait until primochill comes in to stock, and hopefully the bending cords too, and order all then?
Oh, if the 4 packs are due next week then I might pre-order a pack now :eek:
Do you have any comment on the compatibility between Primochill fittings and Monsoon Tubes :confused:
I think it's the other way round?
Primchill are 1/2" OD, so it's 12.7mm, whereas Monsoon's are 13mm OD.
hmm,
I only know that I've tried putting both in monsoon fittings and the primochill needed to be sanded down to fit in the collar, whereas the monsoon is snug.
That very well could have been a quality control thing, and it's meant to be 12.7
bending tubes are only availibe with the Kits now Caseking have terminted the line :/
Does that include the Primochill bending cord? as I have just ordered one along with the tubing etc. If so - why are they still listed - causes confusion and now likely frustration as I will have to order a kit for £12 with items I don't need. :(
Mark
Think I will just have to contact CS and cancel the whole order. What a nuisance.
@ Twst
Any chance that there are B Grade items still to be scaned to the system.
Got an email saying one of the radiators cant be sent due to double scan.
Just wondering if there might be any other EX140/EX280 Radiators to be scanned onto system
