Can you still just boost out of interdiction scenarios without getting into combat?
Yes, and to be honest its what I do 99% of the time as the interdiction is usually a distration to what you are wanting to do at the time. Not sure it is so effective against actual real players though.
Try to make sure you align with the escape vector thing in the interdiction as if you don't when you drop out you might still take some damage (this is true even if you submit to the interdiction, which if you are a trader I would recommend you do as not only do you avoid damage but you also get a bit of a headstart in the running away)
Thanks Greg. There are so many mappings on my Hotas and KB and I didn't even realise there was a boost. If I have seen it, I've never used it. I'll reassign it later
I had a strange mission yesterday or 2 in fact... I was asked to donate 40K to the war efforst in Hutton Orbital, which I didAnd then a bit later on, I was asked to donate 4M to the war efforst in Hutton Orbital, which I didn't do.... I am now wondering if that wouldn't have pushed my standing up to a point of getting the last federation rank?
I achieved last rank in Empire without donating any money (apart from the occasional donate food, slaves, etc.), if you just keep plugging away with faction rep you'll get offered a promotion sooner or later!
Upon interdiction throttle to zero and submit. As soon as you get pulled out of supercruise assign four pips to your engines and hit boost away from the NPC. When your engine capacitor has fully recharged then boost again, repeat until your FSD is cooled down and you can re-engage supercruise away from the NPC.
you don't need to wait for your capacitor to refill, just wait for the thrust of the current boost start to die off and boost again.
Once you start to upgrade (particularly power distributor) you don't need to wait for your capacitor to refill, just wait for the thrust of the current boost start to die off and boost again. Also I've found it a good habit to go to 4 engine pips before I jump so if I am interdicted and submit out it's one less thing to worry about and get straight on with boosting the hell out of there.
Apsilon, am guessing if you don't use boost then you arent aware of the following established method of escaping interdiction?
Simples.
Discovered my first Earth-like world!
Funny thing is that I stumbled upon it by accident; after travelling over 5k LY out from Sol and past the Lagoon Nebula I found a huge area of undiscovered space and visited over 80 spectral class K, G and F stars hoping to find an Earth-like planet, only to be disappointed every time.
Eventually I got fed up and plotted a course home; whilst refuelling at a red dwarf star only 700 LY from Sol I performed a long range scan only to find a previously undiscovered Earth-like planet! So I scanned it and double timed it back to human space to get my name on it. Guess it goes to show that the best way to find something is to stop looking for it!![]()
