- 30 Oct 2014
- Norfolk
I'm just curious whats the best way to clean a mob/dust etc? brushes?
			Soft paint brush and a can of compressed air works well.
+1
Has worked perfectly for me in the past!
+2 but l bought a small 240v inflatable air pump £12 10yrs ago works a treat, beats a air duster hands down, eco friendly as well.
 ), is this ok to use?  Will save me a couple of quid not using compressed air and my PC needs a damn good clean.
 ), is this ok to use?  Will save me a couple of quid not using compressed air and my PC needs a damn good clean.I've got a pump that came with my inflateable bed (honestly, it's for a bed), is this ok to use? Will save me a couple of quid not using compressed air and my PC needs a damn good clean.
Dude, you're in the same town as me - I've got a 1/2 (ish) empty can of compressed air if you want to try that?
Sorry to go OT but just noticed your sig and we've got the same board & cpu. I can't seem to get my 2600k over 4.4, any chance you could trust me your bios settings so I can see if I can get it to 4.5.
Make sure the motherboard is grounded so that it can dissipate any static build up.
Just to clarify - leave PSU plugged in just switched off at mains, right? I want to know how to clean my PC properly without buggering it up too lol
Sure - I actually re-applied it the other day due to changing RAM and still have the settings - will send mine over!
