- 16 Oct 2014
Afternoon All,
So I've gone and got myself my first motorbike! I've only had it a couple weeks now and I'm absolutely loving being apart of the biker community. So much easier getting around and I just find traffic fun now as I can just pass right by it.
However, I'm having an issue where the bike doesn't always want to go into gear properly. Sometimes it happens when I'm in neutral it wont kick down into 1st gear. (Releasing the clutch and pulling it back in fixes this). Also if I'm coming up to a junction in any gear higher than 3rd and I come down to 1st the bike refuses to go any lower than 2 and just stalls when I try pull away without an ungodly amount of revs. Should I be 'rolling down' the gears as I approach junctions?
Is it just something wrong with my technique which is causing this? I.e not working my way down the gears while I'm slowing down?
Cheers for any responses,
Mac
Mac
Like I said if it gets stuck neutral just releasing the clutch and pulling it back in does the job. Just I got caught short over the white line yesterday holding up about 5+ cars as my bike didn't want to find 1st gear. Was probably in 3rd/4th coming up to the line.
basically, to change gear smoothly on a bike, the gearbox has to be spinning, whether that's clutch pulled in, in gear and bike moving (which moves the gearbox from the front sprocket end) or clutch out and engine moving the gearbox while in neutral/in gear.
