- 22 Jul 2012
- London
There's nothing wrong with the screen unless you're trying to view it in direct sunlight or something.
Finally deciding I do not like custards after trying Mothers Milk, Goose Juice, Daredevils, Cardinals Custard, and Monkey Zizz. I kind of find them ok with Daredevils being the creamiest and best by far, though none I would buy again. They all have the same naff, fake, custardy, off taste and varying degrees of that fake, burnt sugar tasting, ethyl maltol or whatever it's called. I love the smell of that stuf, though it always has a chemical, unnatural, off putting taste to me.
Got some Grants coming on Monday, surely if I do not like that I can call off the custard search.
*Has a few chugs on a Mutation X filled with Monkey Zizz. Hmm, I so want to like these custards.There are elements of the vape I love though they all have the above mentioned downfalls for me. Again Daredevils was the best of the bunch for me as the creamyness was so good I could go back to it easier, even with the flaws.
I've gave up on custards too. Not liked any of them so far, I do like ethyl maltol so it isn't that. The custards smell good and aren't the worst taste but they aren't my thing. I've never tried Grants but I don't think I'd like it, I just don't like custard vapes and not point pushing it. Bit like I always order another T juice flavour with Red Astaire and haven't liked any of their other flavours. Black and blue is okay but not something I'd buy again.
What's the best box mod available at the moment. Looking to buy one.
See for me the Lemo Drop should work at higher watts than 20 imo.
I have coiled and wicked this in so many ways with always the same result that it leaves me frustrated as I know it should work.
I did notice something yesterday however. Do any of you guys use the rubber ring in the fill hole instead of the screw?.
I do but on closer examination it looks like it actually restricts some of the airflow from the 4 outer holes. I know it has to be a wicking and/or airflow problem but my OCD won't let me rest till I conquer this wonderful piece of junk atty.
Me, I say a zero with sx350 chip![]()
Sigelei 150w most solid best value one IMO. Then again you may pick up a bargain on a 100w.
They are only going to get better and go down in price one would think now, these serial box mods.
