295x2 Radiator Fan Broken
12 Jul 2009
N.Ireland
So I've just installed my 295x2 last week with an sp120 fan, though unfortunately I haven't had time to test it properly.
I was just tidying away the boxes when I looked at the original fan and noticed 4 cracks at the fan/frame supports. A gently push of the fan and it popped out of the frame. (See picture below in spoiler).
I'm just hoping the gpu is not damaged, it must have been some impact to damage the fan that much!
As its brand new, should I return it, OR run some tests to confirm the gpu is working. (Aesthetically it seems fine). Though there is always the chance of a problem occurring further down the road.
Any suggestions? Thanks.
Just test the card and see if it works okay, it could just be a manufacture defect that made the fan have some crack in it. See what others say before taking my opinion though ;)
As above, if the gpu works well I'd keep it seeing as you're going to replace the fan anyway.
Inform the retailer now though and show them the picture so you have it on record should you ever have to return the card in the future.
I got it from here, will send them an email now.
Can't wait to use this card, just need the time :p
So I have done a few tests and updated drivers to 14.12. However things aren't looking to great.
Unigine Valley Benchmark Score: 4186
Compared to 5528 @ http://www.bit-tech.net/hardware/graphics/2014/04/08/amd-radeon-r9-295x2-review/8 (used exact same settings)
Their test setup uses an i5 3570k, I have a 4790K (Everything at stock)
Any ideas why my score is so much lower?
Any other benchmarks I can run to compare like for like?
Did you copy their settings exactly? They're using x0 AA.
Copy the settings Humbug uses in the Valley thread to compare then post the result here and I'll compare to mine. :)
Yes I used x0 AA
Cheers :D
Using the Extreme HD setting as per Humbug's post I got:
Score: 3774 (Min=32fps , Max=164fps)
Are you running in full screen mode?
This is what i got.
What drivers are you using?
Take a look at my Crossfire thread and setup an OSD, it should allow us to diagnose any potential issues easier like low gpu usage etc. :)
This is what i got.
I'm using the latest drivers: 14.12 in full screen mode
Followed your Crossfire thread, see spoilers below:
(vram, ram, cpu usage have been excluded but were well below 100%)
Best result so far:
GPU Usage during benchmark [Min=38%, Max=98%, Avg(approx)= 75%]
Above results are best after 10 benchmarks. Not sure why gpu usage is averaging 70-75% across both cores? Perhaps it's just a low performing card?
Best result so far:
Your results look spot on, stop worrying.
This bench is bottlenecking our cards, so cpu grunt plays a part here which will explain some difference between our cards. Focus on playing games and allow the 295x2 to stretch it's legs.
Enjoy your card.
This is what i got.
That is a little bit low compared to a pair of 290Xs running the same clocks.
Here is one I did the other day for another forum.
I was running the CPU @4.0ghz for the above.
The difference could be down to the huge bandwidth going through one slot with the 295X2. Valley does cause some terrible bottlenecks.
Enjoy your card.
Okay this is weird,
In valley benchmark, frame rate varies constantly. However around the middle of each scene it stays static for a few seconds.
  • With MSI Afterburner running in background, Stactic fps = 100, Score = 4200
  • With MSI Afterburner closed, Stactic fps = 64, Score = 3800
I've tested this multiple times and consistently get the same results.
So MSI Afterburner increases performance by 10%
I would say overclock your cpu to 4.2 (should easy enough) and try again.
4790k is running at 4.2/4.4 turbo
This is what i got.
I think you might be right Kaap, i put my 8GB 290X Elpida cards back in and scored this with the cpu at 4Ghz. :eek:
What did you get using just two 290Xs ?
This is what I was running in my post above.
Valley is really very bad to use for any serious testing.
EDIT,
Sorry Kaap i see what you mean. :D
I forgot to disable two cards, oh well. :p
