I’ve been playing for over 20 years and I must have spent a few grand on everything from proper milspec gear to high end ammo, full comms setup with throat mics and milspec laser sights. Funnily enough I had the most fun when I had less gear and had camo trousers and t-shirt. As with any hobby you have the people who want to own all the best gear, which is fair enough, but they tend to be nursing their kit throughout each game, not wanting to get it dirty as it cost them a small fortune.
Also people tend to buy the gun because of looks rather than function or even knowing what sort of gun suits them.
Best bit of advice for a noob is to go to an airsoft event and hire out the gear and see you actually enjoy playing the game. Often places have a reasonable range of guns from MP5's to AK Spetsnaz but I would really say to just run with their stuff for a few games to see if you like it. Perhaps other players will let you have a few rounds (or even a game if they’re nice enough) with one of their guns.
Once you've played a few times you will probably find the sort of 'style' of play that suits you. For me it either involved running like a loon playing capture the flag or hanging back and picking off targets in a defence/offence game.
I've probably owned most of the gear mentioned on this thread over the years and there are certainly some good suggestions but also some bad choices there IMO.
Pistol isn’t always a bad place to start and for me I would say over 50% of my time playing would have been running a cheap GBB Beretta with a few mags – it game me freedom to move about and is a bit more stealth than hammering off 200 rounds to pick of one guy, only to give away your position to everyone else in the process.
I would personally stay away from any and all part/all metal weapons, particularly GBB as they only serve to waste a bunch of gas. Don’t rule out electric pistols either, much lighter and far cheaper to run.
I’ve owned so many branded weapons as well but Tokyo Marui is (for me) the go to brand. Well made, good price point and spares are easy to come by. Often they are quite upgradable as well.
The P90 I never got on with, as with bullpup weapons in general (FAMAS) and is absolutely down to taste but particularly the P90 the magazine changes are slow and fiddly. Same with the SA80.
G36 is a bulky weapon and actually I found not very easy to be prone and aim due to height of magazines/body. It is a robust bit of kit and hicappa mags are cheap. These interlock as well so you can have a spare mag always at the ready.
Sig 550 is definitely a great alternative to the G36 in that it also has the foldable stock and the interlocking magazines but the profile of the weapon means it’s far more practical.
AK47 is OK but not easily upgradable. I found it quite bulky and for me had the reputation of a noob weapon anyway.
AR-15 style is typically the most popular style due to RIS rails so you can bolt on your ACog scopes, lasers, grips, torches etc. I’ve never been a fan as I found there was too much to go wrong with them and a right pig to clean. H&K style weapons would be a better bet for all round reliability/strength/low maintenance.
The most robust and upgradable I have found is the Tokyo Marui H&K MC51, I had mine to upwards of 350-400 fps (I had a minimum engagement range) but even in standard form they make for a great allrounder.
Lots of guys locally have been running the MP7 for a few years, it's a great little gun and with the foldable stock, compact size and customisation, it makes for a worthy all rounder (I believe the real MP7 was a direct replacement for the MP5).
Always wanted an MP5SD6 with a solid stock but never managed to get one. One day perhaps!
Best weapon I ever owned was a Tanaka Mauser Kar98k. I had a beautiful scope for it, upgraded seals and ran .35g with several spare mags. I could accurately pick off people from a couple of hundred metres but had a minimum of 25mtr engagement range (hence the pistol). Stupidly I sold it.
Another weapon that was reliable but very cheap to run was the Tokyo Marui M3 Benelli Super 90 shotgun. The shells had 30 pellet capacity and fired three shots at once and was a great CQB option.
It is worth noting that some sites have FPS restrictions and may test your gun(s) so you might want to find that out first as I have known some people come with all the kit and have to hire out guns as theirs is too powerful for the site. Also some sites run more gas or spring games which means that if you only have an electric gun you wouldn’t be able to play.
Hope that helps, it is a great hobby to get into and I have met some great people from it over the years. Also, don't let the haters tell you that paintball is better - it isn't
