Not in 90% of games. Few games go over 4GB @4K, save for direct console ports.
Try Shadow of Mordor
Which two cards are you trying to compare ?
more memory can effect the overclock tho right?
or is that usually by not a lot?
+1
Someone could use a 390X with 4gb of HBM which would have all the bandwidth they could possibly dream of but it would still be slower than a Titan X @2160p as it still only has 4gb.![]()
well you guys were comparing the first titan to the 680, but this titan is coming out in a different order with the 980 already out??
maybe comparing the 1st titan to the 780 would give closer idea what to expect?![]()
ETA on this?
Soon. No one knows yet, but sooner than the AMD.
How it should've looked IMO
Don't know what they thought keeping that silver part on the sides, looks horrible. But well, they're easy to paint, but would be a shame if it's £999+![]()
390X could have 4, 6, 8, 12 GB for all we know![]()
If they're £799 then I'll get a pair. There, I said it![]()
If you want to compare the orig Titan to a 780 it is quite easy providing you run them at the same clocks.
Original Titan 14 SMX
780 12 SMX
Then it is just a case of using a calculator.
Where it goes a bit wrong is because the 780 has less active transistors in the core, it can overclock slightly higher than the Titan which will close the gap a little.
Just wondering what people reckon.Will the Titan x be able to power bf4 full ultra settings 120 fps+. Atm my 2 980s can get between 65-100 fps but they hit 80+ degrees and the system fans make a racket so I would be happy to switch if it's quieter![]()
