So you played it for a bit while drunk and that's your conclusion - well done review of the year.
The conclusion is that different people like different stuff.
The fans in the PS4 DO get noisy sometimes but it's not that bad and nowhere near as bad as how loud the 360 disc drive used to be.
Not on mine they don't. Must have got a good one then.
Some people are more or less sensitive to sound than others. I don't find my PS4 particularly noisy either in general, but it can be loud sometimes.
I'm looking to buy one of these consoles in the coming months for the arrival of Witcher 3 (I know PC would be best but I'll stick with console for convenience).
Onto the question of gfx, am I likely to notice much gain on the PS4? I know as developers get more time with the hardware results improve, meaning the XO shouldn't be that far behind.
Is there anything that should sway me more to one than the other, e.g. noise?
The gap won't narrow. It might not be something people want to hear, but it really won't narrow. Any improvements the Xbox One will make, the PS4 will make similar ones.
The bottom line is if you're buying an Xbox One, the power difference shouldn't be that much of an issue as you're more than likely buying it for the games you can only get on the Xbox One.
The same reason people buy a Wii U, because of the exclusive Nintendo games only available on the Wii U. It being less powerful for some reason doesn't seem to be argued that much, or people don't seem to think the gap between the Wii U and other consoles will close, because well, it doesn't matter.
If you're mainly bothered about the power of the hardware, buy a PC.
So much nonsense in here.
I want a magical silent PS4 and all these exclusives that nobody seems able to name. Christ almighty.
I sit about 8-10 feet away but the console has to transmit through a very high quality mattress (£1400) as it's lower down than the bed.
I was having a good chat with a mate who is a game developer over the weekend and he was saying that the biggest issue they are facing is not really GPU grunt it's actually the weak CPU's holding them back more and causing more development issues.
I have both and regularly play on them both and tbh I see no great difference each has some great games.
Personally I would ignore any comments about power and go with whichever has the games you like and which most your friends have.
