Guys got any suggestions for good batteries been a while since ive needed to buy one xD.
Whats the hot stuff going these days? I am using a regulated box mod DNA30.
Samsung 25r's, seam to last longer than others,
Has anyone been following this ban on tanks over 2ml nonsense thats supposed to be happening in may? If thats the case Im going to grab a couple of tanks and spares to stock up.
Also,I find myself preparing for the entirely possible massive tax on vape related products and have decided to try a spot of DIY. I know Im a bit behind on this so anyone got any good recipes? No tobacco or menthols please. Big fan of rhubarb and custard but never been able to find a decent one
Yes but it shouldn't stop us buying from our friends in the East. The best thing I did was take the step into mixing myself. It is easy, cheap and very rewarding.I can see me stocking up on PG Nic as that can (apparently) last upto ten years in a freezer.
Check this post here.
Try the one "*swearyword* Incredible" It contains Cactus and as the name suggests it is indeed incredible.
I know what you mean oldestgregg. At least you have a year at minimum to gather as many as your wallet will allow.
Hope you don't mind me giving advice but get your PG and VG from Classikool from the bay. Make sure the VG is the pharma grade mind
72mg Nic I buy is £8.49 after discount (POTV15) from vapeinc but that is for 100ml. They do 1 litre bottles although they are sold out at this current moment.
anything from Torchy mate; so you you it's legit.
http://www.ebay.co.uk/sch/big_f_d_d..._DefaultDomain_3&rt=nc&_trksid=p2047675.l2562
It all depends how you vape.. if you sub ohm a lot your need something that's high amp... if not; go for something that's high mah.
Thanks bud,
Would 30a be fine instead of 20a?
I was looking at these for my mod -
http://www.ebay.co.uk/itm/2x-30A-Torchy-Samsung-25R-2500mAh-Flat-Top-18650-3-7v-Li-ion-batteries-case-/291402172674?pt=LH_DefaultDomain_3&hash=item43d8ec4902
Yeah, that's the Samsung 25R people are raving about.. I have a new set myself, just not rewrapped.
The 20a/30a refers to the amp.. How fast the battery can give the power out, this is much needed for lower ohms as it's safer. The bigger the number the more juice it can pump.
The mah is how much power the battery can hold to begin with.. Battery tech has moved forward since the DNA 30 came up, so your likely to find that the new battery has more mah and can give more power.
Edit: remember to get the battery in the right way round, as it will blow your dna 30 up.
