Find an extra £20 and get this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-323-SP&groupid=701&catid=56
I'm not sure about the dimensions of the case you're talking about, but if space is very tight... :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-159-GI&groupid=701&catid=1914&subcat=2379
I'd put one of these http://www.overclockers.co.uk/showproduct.php?prodid=HS-068-AR&groupid=701&catid=2330&subcat=787 on a good used GTX680.and still under £180.00
Andi.
I tried all sorts of tricks with my 280x. Whilst a decent card just produces much more heat than equivalent nvidia cards. I had a kfa2 gtx 760 which would have been perfect but I sold it.
So they probably kick out 1.2/1.25v , which if undervolted to 1.05/1.15v would provide a 10c temp drop with a cusyom fan profile making it quiet.
What did you try?
I got the 280x quiet at idle and in a big excellent vented case with lots of space and airflow (fan profiles mainly and excellent case cooling) it was ideal but it developed bad vram within a week so I sent it back.
Get an Gigabyte GTX 960 Mini-ITX and clock it, roughly gtx 770 performance for £130 after you sell the witcher 2 code.
Check out boomstick's review.
http://forums.overclockers.co.uk/showthread.php?t=18661085
