Windows Server 2012 R2
Permabanned
28 Dec 2009
london
If you are implementing new servers are you all using 2012?
I have to create a new sql 2012 server and considering using server 2012 r2, do you think this is the best choice?
As much as I hate 2012 i think I am going to have bite the bullet and just put up with it.
At least with R2 they have the ability to right click on the start menu, I am just realy going to miss the old server manager, it was so much more logical.
Is anyone still implementing 2008 because they dislike 2012 so much? Or is it just me who has held off this long?
I implement servers at work for people to use to do work on. Remote Desktop to and run software on there.. On a few occasions I've had to deploy 2012.... I hate it. It's confusing to work around and even something like terminal services / Remote Desktop services is confusing on 2012!
You just have to get on with it. May take a while to get used to it, but once you are it's fine, honestly.
2012 R2 mostly. Our SQL 2012 Cluster runs on 2008 R2 but I will be moving it to 2012 R2 when we go to SQL 2014 later this year.
I can't think of a good reason to stay on the earlier versions of Windows, 2012 R2 is just better in every regard.
Like everything Microsoft do - they don't explain any of the good stuff in 2012 R2. Use Server Manager for all your GUI administration. Everything revolves around Server Pools, once you start treating individual VMs as homogenous units it makes a lot more sense.
If you're using Windows 8.1 put the RSAT tools on your computer and marvel at how easy it is to administer all of your servers from your desktop instead of having to log on to each one to do stuff. Throw Powershell 5.0 into the mix and you're cooking on gas.
Everything I install is on Windows 2012 R2 Unless software demands otherwise.
I have no problems with 2012/2012 r2 and think it works really well.
2012/r2 is a amazing improvement over 2008/r2, if you can get away with using core then its ever better.
I'm starting to get really annoyed by managing 2008 servers now.
Given that 2008 is the same kernel as Vista and 2008R2 the same as Win7, I'm presuming 2012 & 2012R2 are using the Win8 & 8.1 kernels respectively?
I assume that Server 2016 will be early next year and use the Windows 10 kernel.
Hated 2012 to start with, give it a month, now love it.
The Hyper-V technology is coming along nicely too which is a bonus :)
All our new physical servers are running 2012 R2 Datacenter edition, most of which are in a fail-over cluster environment. All our new virtual servers as running 2012 R2 as well.
Question for you. How well does Hyper-V cope with fail-over? I've read some horror stories about splitbraining which has kept me using VMWare.
We've not had any issues arise as of yet (touch wood) with the fail-over cluster splitbraining at all. To be fair, the cluster has been pretty stable. Although that's not to say that we haven't had issues, but the issues we've had have been more down to the OS as opposed to the cluster itself.
We are also running SQL Server 2014 in a fail-over cluster environment as well, so are running a cluster within a cluster to add an extra complexity to things lol.
We currently have two main fail-over clusters running at the moment;
6 node (IBM x3550) cluster hosting approximately 30-40 virtual servers at present.
5 node (IBM x3650) cluster hosting approximately 70-80 virtual servers at present.
