Bird strike, engine failure, fuel starvation or leak
Those could be single point of failures
Very very few are, but not never
None of those are single points of failure.
I would love to elaborate on why you are wrong, but I work in aircraft maintenance and many of my colleagues use this site and for the sake of my job or people thinking I was talking about my own airline I just deleted the 500 word post I was about to makeI wouldn't want a link to be made wrongly that cost me my job
No it doesn't. Which is why you have an accountable manager at an airline. Not only the man furthest back carries the can. After all look at who is and isn't in prison for the helios incident. If the man on the tools so to speak hasn't been properly trained and supported he won't be the man in jail.
I worked with the man that signed off the Helios flight and was the engineer on the radio when it all happened. I pray I never have to go through what he did for years. I hope I'm never in the shoes of these people that worked on the German Wings aircraft. It's bad enough for the anxiety mislaying a tool for a few hours let alone losing that many lives.
Not that relevant really with so much maintenance done at night these days, it could have been the first leg of the day. Also nothing to say it has to fail straight after maintenance.
They did, you can't monitor for a pair of pilots badly trained.
Thanks for taking the time to write that.
[TW]Fox;27820717 said:None of those are single points of failure.
Bird strike or foreign object in to an engine? How is that not a single point?
What about the effect of a failed rudder causing a plane to ditch and spin, caused by aggressive pilot rudder
movements
Cause and effect
A single engine failure doesn't mean that an aircraft will suddenly plummet ouf of the skies like a stone. They still have their momentum to carry them a bit forward and pilots are generally trained to use flaps / ailerons combined with the remaining engine (s) to generate forward motion to keep the plane airborne until such time that it is possible to land safely.
As for the engineering thing, a friend of mine is an aircraft technician for SAA and some of the stories he's told me would easily make some folks never want to fly again.
Like on one occasion using a hydraulic system from a completely different aircraft to power some or other moving bits, but only on one wing. The other wing had all the original gubbins, so they relied on the on-board systems to keep the aircraft stable during a long haul flight as the two systems had completely different calibration parameters.
I know that, but the outcome has unknown variables, it could go either way. You could navigate to a nearest airport, land in the Hudson, or have no variable terrain to land safely on.
I do know how aircraft function
. It put me off flying for the next 10 years.
just heard the plane had just received a service/maintenance.
it's likely that something was done incorrectly/not set back from the settings needed for maintenance.
In this very vague story that I don't believe (from his point not yours), if your friend didn't report this to the authorities he's the biggest ****ing idiot in the whole tale. A disgrace to the industry if he can fit non approved parts to an aircraft and let it fly. Next time you see said friend, tell him he's a buffoon that has no place near an aircraft. I sincerely hope this chimp is not a licensed engineer.
furthermore birds don't tend to fly at 38,000ft. They do get bloody close though. I was surprise to read the max altitudes for some:The only single point of failure I can think of is a bomb or human error.
Double bird strikes like the Hudson can almost be discounted due to their freak nature, it's the only one I know of in modern commercial aviation history.
