Caporegime
- 13 May 2003
- Warwickshire
Hi all
For reasons that probably aren't important, I want to move a radiator from one wall to another, as follows:
The plasterer is in on Thursday so the carpet and underlay will be gone to leave only a suspended floor with relatively easy access to the ventilation gap underneath for pipework.
My intention is to flush the system (combi) and add inhibitor etc. in the process, but I have a few questions about this job.
1. Is this something I should be attempting as a moderately competent DIY plumber, or should I just get someone in?
2. If the latter, how much should I expect to pay?
3. What's the neatest way to run white pipe up to the rad? Currently they're just painted copper, but how do I make the neatest and best-looking connection from the copper under the floorboards to the radiator? Can you get white copper pipe to make the final connection?! or should I just use white plastic for the whole pipe run?
4. Most reliable way to terminate the old pipes? Cuprofit-style push fit copper end stop acceptable?
5. Any other thoughts or tips most welcome!
Cheers.
Cheers.
