It's probably a scenario they can't really account for. There needs to be a way to block all access from inside the pilot cabin in the event of a terrorist takeover from the passenger cabin.
All good and well but as we can see problems can happen within the cockpit too, albiet not very often, but if this is true, and we see in other cases, it does happen
What about a combination of chip under skin, pin, and swipecard for over-ride if for what ever reason the pilot cannot gain access back in to the cabin. One of each will not gain access, and the card will never gain access alone
If both pilots are in the cockpit then this still gives the lockout for anyone external, if one pilot leaves and is unable to gain access, like we seen here, they can override it by using a chip under the skin, a swipecard, and a code.
Maybe im going a bit OTT with that theory, but still aswel as the outside of the cockpit being a threat, the inside of the cockpit threats need to be looked in to further
sized planes normally have flight engineers then? Does anyone know?
