We don't know yet, Gibbo said he'd have a look and let us know when they arrive in stock
That's the move I just made & don't regret for one minute. Significantly better performance than a 970 and I recon it will hold it's value betterGoing to have to sell the 680 then![]()
How would a 780ti compare overall with a 290x? It appears that going by Anand that its game dependent, and at higher resolutions the 290x pulls away a bit but overall a bit faster. It runs hot but not apparently quite as hot as the 290x as well. I tend to think of this as a side grade rather than upgrade but what does every one here reckon?
Also when are Ocuk accepting orders for these, already or when they're in stock?
Ahhhhh...to hell with it, just stumped up for one! Its the only card that fits my requirements due to doing a pc case change.
Are you going 8gb 290x to 3gb 780ti ?
I guess the 780ti will be an upgrade from a 480 GTX?(I bought it years ago b grade from the store and hasn't missed a beat!). Does this require the same as 480 gtx? 8 pin + 6 pin?
Edit: Ordered![]()
Should still be 8 + 6 pin but recommended PSU specs for the 780ti are 600w with 42 amps available on the 12v rail.I guess the 780ti will be an upgrade from a 480 GTX?(I bought it years ago b grade from the store and hasn't missed a beat!). Does this require the same as 480 gtx? 8 pin + 6 pin?
Edit: Ordered![]()
After seeing those anandtech scores and surprised the 780ti beats the 970, i have asked ocuk to swap my order for the 770 to it
But now just realised the superflower 550w golden green i ordered wont cut it
