You can't even bring yourself to say "No." Fitting.
I don't need to I wrote MAYBE. But the general consensus is Suicide
Source on that general consensus?
The biggest criticism of autonomous planes is that they can be hijacked or develop a fault.
Oh Behave.
Does it need to just be flicked once, or do you need to keep flicking the switch?
They kept talking about a lock out for between 5-20 minutes.
Could for example, a person have a faint, flick the switch downwards in a last action by grasping for it in error, and then leave the door on lock while being unresponsive? (not this situation but hypothetical)
TBH I'm not positive on the time frame when you have switched it. As I said before I have only done it in jest to lock a boss out of the plane and each time he put the code in I just kept rejecting it. I have read that once you lock/reject they are locked out (by code) for 5 minutes but I have never had reason to test it. If the pilot did it in error he could still select open straight after.
You couldn't faint and lean on the switch of keep it pressed, the sides of the switch are raised up and the toggle is back to neutral. The side guards on the switch would even prevent operation if you fell on the console.
Here's a picture:
http://prod.static9.net.au/~/media/images/2015/march/26/150327_raw_a320_vid.ashx?w=718
Can't believe it's come to light he was signed off work by the doctor and he chose to go in anyway. All seems so... preventable..![]()
Maybe....maybe not.
But my post still stands.
since 1999 it looks like more suicidal pilots have killed more passengers than terrorists.
So we fixed one problem but created another.
Maybe....maybe not.
What do you expect. You only have to to look at this forums attitude towards depression and manning up and getting on with it to know why so many people with depression in all walks of life carry on going in.
People just treat you like you have taken a sickie, I have known engineers be phoned up and asked to stop taking the ****. I was in a very serious accident a few years ago which took me a long while to get over. I stupidly returned to work the following week. In my back to work interview I requested not to be put on anything too technical as my head wasn't right but I didn't want to sit at home. I was then put on about the most important and technical job we had a massive rebuild with stacks of flying control inspections and functions. To this day I'm not sure I did anything right and I'm glad that aircraft isn't in service anymore. I just tried to do stupidly what everyone says you should do, man up.
Thankfully I no longer work for a company with 1940's attitudes towards stress.
A completely autonomous plane could definitely not be hijacked as there wouldn't even be any controls for someone to take over on the aircraft. And planes as they are develop faults, they are rarely catastrophic and the computer systems often have fail-safes to compensate for the failure of some component.
Modern aircraft are essentially flown by computers anyway, I'm all for going towards the next step and testing complete automation flights. Just look at the self-driving car industry - the cars developed by Google have a fantastic track record with almost zero incidents. It is time to start replacing humans with computers as far as aircraft technology is concerned.
Can only think it would have been something like stress.They confirmed it wasn't depression though. It was something else that the doc deemed him unfit for work for.
Not to be morbid, but crashing at this speed is it literally instant death for those on board, would the body even register the gforce of the impact?
As far as plane crashes go this has to be preferable, compared to a loss of control and eventually crashing 32 mins later as happened with that Japanese Boeing flight.
[TW]Fox;27836344 said:The massive flaw in your thinking is that the 1999 Egypt Air disaster predated the 9 11 security increases...
Doesn't stand at all, you are forgetting the thousands killed on the ground.
And procedure are now updated again. Many have already implemented minimum of two in cockpit. Not that it'll stop all situations. But you never will.
And then you can't even estimate lives saved through the introduction of locked cockpit.
There was the one in america, was it a fed ex cargo plane. Where one worker wanted to crash the plane and claim life insurance for family. Thankfully the other pilots managed to fight him off somehow. Despite being badly injured.
The other massive flaw is that terrorists hijacking planes have killed a few thousand in that time frame, completely dwarfing all deaths as the result of "Suicidal pilots" combined.
