Hang on.
I wrote since 1999 suicidal pilots have killed more passengers than terrorists.
Then it gets thrown back that it pre dates the 9/11 changes. Well it will do I said 1999 which is before 2001.
Why discount those killed in the ground, no reason to do it.
And yes since 1999, so you are including 13 years when rules where in place to massively discourage hijackings and therefore skewing the results even more.
No, jumping to 2001 is even worse as you are only including dates after massive procedural changes to discourage hijackings. And therefore your suggestion that the procedures has caused more deaths is laughably stupid with the data you've provided.
