Airbus A320 Crashes in Alps
Almost to Australia.
What a stupid meaningless factually incorrect pathetic statement that means absolutely nothing. I expected much more from you especially as you seem to like to pick holes in other peoples comments
If you dig a hole from Great Britain you'll end up south east of New zealand.
So looks like both of us have failed
Ahhhh the Gimli Glider, you have a good memory, & it's the perfect example of why no matter how sophisticated the software solution is, it cannot trump the hands on approach of an experienced, knowledgeable, human pilot.
There will allways be that unthinkable scenario that makes an experienced pilot sweat, but completely stumps a computer.
Aye, I couldn't remember the name but remembered reading about it (in a Readers Digest amongst other places), and it was on Air Crash Investigators :)
Another thought that occurs to me is that even in modern aircraft there are often situations that require human muscle power to initiate certain emergency systems, or deal with certain situations.
For example a smoke detector and breaker monitoring might be able to pick up on a fault in a bunch of wiring, but a human might be able to work out if the wiring is the fault, or just a sympton and further action is needed (is the wiring overheating because of a short/too much current draw, or is it because there is a fire next to it).
You think that proves that you are at more risk of a suicidal pilot than a terrorist pilot, do you?
p.s. the hijacking list is bigger than the suicidal list.
Are you really that desperate to try and get one over on someone that you've forgotten how to read.
We are talking about deaths.
So trot off and go count them
No, you were talking about risk. Higher number of incidents == higher risk. You need to trot off.
p.s. 2,997 were killed by terrorist hijacking in 2001. That number is a lot larger than the number on the wiki page for suicidal pilots page. Please learn to read.
More at risk of being killed. Again you failed because your so desperate to get one over
Your being pathetic now.
And I apologise for the sometimes lack of proper punctuation its something us dyslexics can have issues with
Not after sept 10th.
Are you really going to take it upon yourself to point out EVERY meaningless post on this forum..
Your gonna be busy.
Maybe I should have wrote. At this point in time the risk of being killed by a suicidal pilot is greater than being killed by a terrorist pilot
[Citation Needed]
And you fail again.
What happened to 1999
As you can see from the quotes we've moved on from that now to after 9/11 after you so graciously pointed out that we can't compare pre 9/11 to post 9/11 but that still isn't good enough.
And as I said that makes any comparison even worse.
Everyone knows what you were trying to imply with the stupid statement, just admit it.
All depends what you are trying to imply, that determines what you need to compare.
Nothing you've posted so far supports your implied position.
No everyone doesn't and I wasn't. Just because a portion have read something into it that wasn't there and wasn't meant to be there says more about you and them looking for an argument.
So again a total meaningless and stupid post. With no merit, but then you try to defend it. even though it means nothing and is clearly crape, however you look at it. By comparing two things you are making a statement. Otherwise there's no point comparing two figures. Just a shame you didn't think about it, and posted some figures that didn't support your position.
