I bought a computer from OC in 2012 with the following specs (old post):
More recent DxDiag with monitor and peripherals (if relevant?)
I use a dual monitor setup, with my main monitor at 2560x1440 resolution. The only upgrade I have made it to switch in some higher quality RAM (still 16 Gb) as there were some timing/stability issues with the original Corsair RAM.
I have noticed that some games (SC2, Heroes of the Storm, CS:GO) push the limits of my build when I play in Windowed Fullscreen at 2560x1440 resolution. To maintain acceptable fps I have either to play in reduced graphics quality (looks ugly), Fullscreen (don't like as I can't alt+tab easily) or Windowed mode at a lower resolution (don't like as I don't use the full screen).
Four main questions :
Q1) Is it reasonable to assume the GFX card is limiting here? (How can I test, do I need to or is this obvious?)
Q2) Could upgrading to a GTX 970 resolve the issues above? (This chart indicates 3x improvement)
Q3) Which is the quietest GTX 970 (under load) without oging too much over £300?
Q4) Can I simply swap it for the old GTX 560 Ti without needing to upgrade motherboard to take advantage of it?
