Farmed the first area this morning and levelled up my hp, end and str. Also levelled up weapons a bit. Can one shot a lot of mobs now so things do seem a lot easier. Feels more Demons than Dark to me. Loving the setting and atmosphere.
Upto 5th boss now and its not as simple as the others for sure. Trying ludwing sword, seems really good. Just not a fan of the 2 hand mode
I tried this last night but it seemed to screw up for me. Suspend booted me back to the bloodborne menu and said only offline was available. It did try to connect but it kept failing.
It seemed to screw up everything and my system jammed up, so I had to hold down power button on ps4.
Maybe a blip but not the greatest experience trying suspend mode for the first time.
Also only just thought about covenants! I assume they arent in this, ive not seen any yet? Also not been invaded at all which is good really but thought i would have been by now
HiDo you have it set to keep internet going once in suspended mode? If not that might be why.
You will learn to love 2H mode. The charge attack will one shot medium hp enemies, most others will die in the follow through attack. It completely removes any risk of engaging most trash as if you time it right the enemy will die just as it enters attack range.
I've restarted. And the first werewolf type beast you see before you are meant to die so as you enter hunters dream and get a weapon, I so nearly had with my fist's... Bugger lol I'd have had him if I'd not got stuck between a table and he cornered me.
I shall give it more timei noticed l2 and r2 do different attacks aswell
Cleric Beast was the easiest thing ever, accidentally stumbled upon it and killed it first time.
Father Gascgoine is harder though.
Any tips for the cleric.![]()
Don't lock on.
Run around behind him and charge R2 attacks if you're struggling IMO, he seems to react instantly to the first hit he receives regardless of what he is doing, so charge an R2 and move out or just get prepared to dodge
Mainly don't lock on and just run around him though
