This is called Intel speedstep technology iirc. It's a cpu function that will reduce power usage by reducing clock speed and voltage when in low usage. It's completely normal but you can turn it off.
Unless you're making music and need loads of real-time effects leave the power settings at defaults. The CPU is designed to change speed depending on usage.
