- 19 Nov 2011
Wow, just wow, great build Dave!
What spray paint did you used for painting?
its actually just cheap automotive paint, as long as your not too crazy with it you can get some good results
depends entirely on what it is tbh buddy, if it has a rubber coating or is really glossy, i will give it a quick rub with some wet and dry just so the primer sticks better![]()
Nice one Davido,will pop over to vote![]()
Thanks! Brilliant work, my vote is yours !
Cheers mate, i'm going to do the same with my hyper x SSD's when home in the summer.
Presumably taking them apart voids warranty?
Check out Pandora's tight wet purple box Here
yeah, you have to either remove or puncture the warranty sticker on the back. Its not a massive issue for me as they are sponsored products, so please do be careful, i wouldn't want to see my ideas have broken your SSDs =(!!
make sure you take some pics! I will send them to HyperX and show them your work!
