- 25 Nov 2011
- The KOP
I understood all the time and you was the one getting all worked upWhat did you think a double frame was for? That is why G-Sync is far superior to Freesync in the lower frames
Anyway, that is my last word on that and I have had my digs at AMD, so will leave it there![]()
No you never you said 30fps would be 60fps using Gsync lol
Even went and asked pcper to see if you was correct.
Posted by Gregster
Great video and explains a lot of why gaming is so smooth on the Swift. Can you confirm to settle an argument that 30fps on the swift is actually running at 60Hz with an extra frame being sent, so in effect is 60 fps?
Lie much?
No problem, we all learn something am happy to help you out when you wrong. I expect the same from you.
GSync can have the lower end pcper rate Freesync the best on the higher end. I'll take that.
One last edit
I know what the double frame was for always have. Remove screen tear, when the VRR is gone.
