There's no reason the edge should have significantly better battery life than the reg S6.
Don't forget that extra 50mAh
Haha
Haha
Key word there was significantly
Anyway - seems battery life is decent considering the Z3 got
GSM Arena stats usually quite accurate?
Not the best - AFAIK they set the brightness to 50% instead of 200nits. As you know 50% brightness varies wildly across different devices. ARS Technica and Anandtech tests will be the most controlled.
Well I would but no one seems to know when they are coming out...
Hope nobody severs an artery with their exploding glass s-bendy.![]()
10-04-2015
Why would you hope that? Wouldn't that leave you less people to feel envious over?![]()
. Just a 5s with a bigger screen felt like I had taken a step backwards.I already have an iPhone 6 Plus why would I be envious of someone with a dangerous, poorer performing knock off?!![]()
The issue I got is finding a 64gb edge for Friday as it seems .de has let me down,
I'd stick it out unless you like throwing money away![]()
** Baiting post deleted **
Just saw this on XDA, looks like a very interesting alternative for a screen protector (and rear protector) for the S6 (especially the Edge)
What are your views? Anyone used this?
http://www.amazon.co.uk/CRYSTALUSION-CLGP2P-Liquid-Glass/dp/B0094EETOG
Should reduce fingerprints too on the black
The battery life does seem poor though, after seeing the usage stats of people's S6's on XDA. The S6 will slow down though like all Samsung Android's, add LP's infamous memory leak, it'll be even worse.
