*** The Official Samsung Galaxy S6/Edge Thread ***
Key word there was significantly :p
Anyway - seems battery life is decent considering the Z3 got
Not the best - AFAIK they set the brightness to 50% instead of 200nits. As you know 50% brightness varies wildly across different devices. ARS Technica and Anandtech tests will be the most controlled.
Ahh okay makes sense
Will be interesting to see what the others say then :)
Had a play with the Edge today, really impressed, feels very premium. If I wanted an Android phone I'd have zero hesitation. HTC are done.
I had a 6 plus for 2 weeks was long enough :p. Just a 5s with a bigger screen felt like I had taken a step backwards.
I already have an iPhone 6 Plus why would I be envious of someone with a dangerous, poorer performing knock off?!;):)
You obviously not seen the test on YouTube where they opening the same apps/games etc on both phones and the S6 was 8 seconds faster overall than the iPhone.
Just saw this on XDA, looks like a very interesting alternative for a screen protector (and rear protector) for the S6 (especially the Edge)
What are your views? Anyone used this?
http://www.amazon.co.uk/CRYSTALUSION-CLGP2P-Liquid-Glass/dp/B0094EETOG
Should reduce fingerprints too on the black
I've used a similar product and would not recommend it; my phone scratched up the same as if I didn't have the product on it. Perhaps because it is impossible to tell if you've put it on correctly.
The battery life does seem poor though, after seeing the usage stats of people's S6's on XDA. The S6 will slow down though like all Samsung Android's, add LP's infamous memory leak, it'll be even worse.
Phones slow down due to user error. People install junk apps and that's what causes slow down.
I can't say I noticed much slow down on the note 4 on lp had it on since the German release came out first., battery not as good as kk though.
