***The Vapers Lounge*** 2.0
Status
Not open for further replies.
http://everythingliquid.co.uk/shop/liquid-nicotine-7-2
Is the cheapest Nic I've ordered, they also do VG for people wanting that. Smallest bottle size is 250ml for £19.99.
thats not bad for a 250ml bottle. works out at £25 inc. its a shame they dont do a 100ml bottle. dont want to get big amount because the last bottle i bought i stopped vaping for a while and i think it went off, all my juices are a red color no,. they still taste ok tho.
Just decant 100ml into a brown glass bottle and stick it into the freezer. Will keep it fresh for a few years.
That's interesting. Can you freeze DIY nicotine solution?
as in nicotine base? yes you can.
Its important to use coloured glass bottles as strong nicotine can leech into plastic.
Also amber bottles stop sunlight getting to it, this helps preserve it.
As sunlight degrades nicotine
I will only keep 100ml or less at room temp or in fridge, all the rest i have is in freezer
It doesn't in fact freeze but the cold temp slows down the reactions. Some people have mass bought cheap nic from the US (talking 10+ litres here) as it is the only thing that the government could control which would effect vaping.
I've been DIYing liquids for about 2 years, in that time I've only used 1 full 250ml bottle (just started my second). I kept that at room temp in a plastic bottle. I think ill be investing in some glass bottles.
I also heard that water can degrade nicotine. No idea if its true. But VG generally has distilled water in it, so that could have an effect on the strength.
Of course my nicotine base also comes premixed with PG, so I guess that's still ok to put in the freezer.
I bought 2 litres of PG Nic base (72mg/ml) in January last year. Only opened up my 3rd 100ml bottle a week or so ago.
All stored in the freezer in labelled brown glass 100ml bottles (from boots, dunno if you can get them any cheaper, but they are easily cheap enough. And make sure you get child proof caps for them). It then gets stored in the fridge until needed again. Never had an issue.
I also bought my PG from ebay at the same time. http://www.ebay.co.uk/itm/130853413769?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
£7.50 per litre. It is stored in the same manner as the nic base.
Excuse the date. They are all marked 2013 when in fact they were all bottles in 2014.
Do you realise many mixers recommend filling the bottle to the very top?
Oxygen oxidizes with nicotine, hence why most juices get darker over time.
But i am not sure if this makes a difference in the freezer, but i brim mine.
Yes I did read that about 6 months after it was all done. Not much I could really do about it by that point really.
The base was actually bought by the kilo as well. So most of the bottles are fuller, but the ones closer to the camera weren't quite there.
Just sorting through my juice, I have quite a bit of 18mg stuff left, around 100ml, am I right in saying if I dilute this say 70/30 with some 0mg nic juice (70% 0mg) it should take it down to around 5-6mg?
Yep sounds right to me, (70 being the 0mg juice) you would need 200ml of 0mg added to 100ml of 18mg to make 300ml of 6mg
Success! My mrs was eyeing my iStick 30W (pink) and finally agreed to try vaping.
I popped some RY4 in an Aerotank 2, dropped it down to 5W and let her rip on it. She likes it.
Finally, she might stop smelling of fags all the time.
So, despite not initially taking to it, I'm hooked on green crack. Just finished off the 30ml bottle I got on Wednesday :eek:
Ordered more of it along with some sticky icky and special K.
Are we paying much more in the UK on the bombZ liquid then in the states? Noticed they have a distributor in Houston, if it's significantly cheaper I'll see if my sister in law fancies shipping me over a few 120ml bottles :D
Status
