Am I also right reading that these are only fast within transfer rates and not booting up windows and games
Seems like it. Only good on benchmarks, not in real life.
Will Z87 boards be able to use these drives as boot?
The advice from Intel is that you should have a X99 or Z97 motherboard with UEFI version 2.3.1, Windows Server 2012 R2, 7, 8 or 8.1, and ideally your motherboard manufacturer should have an updated BIOS that explicitly states that it supports NVMe (check change revision notes).
Apparently some motherboards running different chipsets might work but it's certainly not officially supported or tested.
Yes i spotted they came with a cable. I hope to be getting a sample of the 2.5" drive ASAP so I can play with the drive and get some speeds from it on different systems.
i dont see this as a mainstream solution tho!!??
as i understand it if z97 you choose between this and 2 gfx cards or you need to be x99?
we badly need something mainstream thats faster than sata3, this is gearing up to be enthusiast only unless there's big architecture changes?
maybe i understand it bad ><
or maybe we will get more lanes soon?? is that possible![]()
Any ETA on these?
