Hmmm... question is, will it be delivered? Great price though... am tempted
That's the 32Gb version right? Tempted but I want the 64Gb version as I'm always running out of space on my 32Gb N5.
On the S6 I tried the lights only came on when I touched the buttons. And they turned off after a second.
All previous Samsung devices had the option to turn them off completely, which is what I'm after.
Used most Galaxy S devices upto the Galaxy S4 and I don't recall seing that option.
I've seen it on the note series. I usually keep it set to 6 seconds rather than turn it off completely so not a big deal for me.
1.Go to Setting menu
2.In Device list, tap Display and Wallpaper.
3.There are 4 options that you can select. Check Always off option to disable key lighting.
But when your Galaxy Note 4 Power Saving Mode is enabled, the touch key lighting is always off. If you want to turn on it, follow this guides
1.Go to Setting
2.Choice Power saving in System list
3.Tap Power Saving mode
4.In Restrick performance menu. Un-check the Turn off touch key.
what store/network?
it was from carphone warehouse on Sim free but like i say i shouldn't have had it until the 10th sales man is probably still getting a roasting.
Nice phone been on all day updating apps surfing receiving emails and general use and the battery is still sitting at 49%, so looking good so far.
might do that need to be quick thoughMake yourself a video as the first comercial unboxing+review in English you'll get a ton of views perhaps pay for your next phone.
how are you guys navigating the .de site ?
Cheers,
