***Official GTAV PC Thread*** [Important warning updated in the OP]
GMG for £31, there's key sites of course that will be cheaper but its a risk.
il spam this again incase anyone is still looking to buy from GMG..
you can get some Cashback if you use TCB http://www.topcashback.co.uk/green-man-gaming/
5% if you havnt used GMG before, 2% if you have, they might not pay out if you use a discount code but its worth a try
Quidco are offering the same cashback rate as well
EDIT: TopCashBack are now offering 8% cashback to new GMG buyers, 3% if you've used them before
Anyone heard anything else about needing space for extraction (Steam version)?
It's been yes, then no, then no, and now Steam comments are saying yes you need that extra space..
FFS
It was confirmed(the link is buried in the old thread) that you don't need anymore space for unpacking
on the System Requirements bit on Steam it says 65GB of available hard drive space, if it needs more room than that to unpack then they should have said so :/
will it bork a SSD if it fills it 100% by files unpacking? ive only got 27.5gb spare :o
See above :) I hope this is true.
SLI support now that's great a day before release instead of after release:)
I know, quite a professional launch so far, aside from rock stars servers being on fire lol
I've just bought a wireless Xbox pad for the PC and a new HDMI cable connect my tv for this, just a shame i'm back at work tomorrow after a week off :(
afaik looking about abit you just use a Brazilian proxy to add the game to the basket on nuuvem (Hola will do), then change back to your own ip before you proceed to checkout.
I don't really like these sort of things, might just get from GMG. Cheers! :)
Can someone tell me the cheapest place to get this?
I've heard Nuuvem is cheap but not sure on reliability.
Myself and others have purchased from there and got keys instantly, few others haven't and will receive theirs tomorrow.
Hit and miss, save yourself the trouble get it via steam.
Good news for us AMD peeps.
Source:
