Enjoy the same game but I'm not giving rockstar more money.I thought the same. But it's totally worth it!
Is it just me or is anisotropic filtering broken? I have it set at x16 but textures are very blurry from a relatively short way ahead.
Creating my own radio track list is cool but I think it introduces some stuttering![]()
Can anyone running at 1080p tell me how much vram it uses?
I know that but it doesnt appear to be the case in this instance as the game starts lag spiking when crossfire is enabled but is fine when it is disabled. The game appears to be thinking i have a 6gb gpu and trying to use it all as it see's the 6gb.
Trouble getting online? Anyone else experiencing this problem?
It happens sometimes with me. Did you change gfx settings then told to reboot the game and you let it. When it did did it start with a window instead of fullscreen at all if so that usually tells me the AF will be broken if i alt and enter to fullscreen it and play it. So i quit it and properly relaunch it so the rssc thing comes up then goes then game starts and then it usually fixes it. If not do a reboot of the comp then launch it. Hope it works.
I did have to alt-tab first time playing to get it to play full screen but no issue since and I do restart after making settings changes. Thisk its just the game, to be honest the textures arent all that great either on highest setting.
Im using about 2.4GB (would increase close to 3Gb with a couple settings turned up more) according to afterburner on my 3Gb 7950.
I've only got a 128GB SSD with 70GB free. As this uses more space when its unpacking is it possible for me to install it to a 2TB drive and then move the installation files to my SSD?
Only had one crash in about 8 hours of play today, the loading in multiplayer does seem to take forever at times too.
