[Damien];27924369 said:Good luck on the big ride btw. After a certain point more distance just means more food/water so don't let it intimidate you. Once you know what heart rate level separates 'hard but sustainable' from 'I'm really pushing now' (in my case 170-175bpm) then so long as you skirt that limit without pushing it too much you can go forever. My trick on longer rides (the flat 100m I did and the 85m 12,000ft climb one in majorca for example) were these. A couple of handfuls of the sugary goodness when I felt the fatigue coming and I was off again. Not healthy in the slightest I know but they worked for me.
After covering 1,500km and 24,000m of elevation gain according to Strava within the first 3 months of the year, I have been back on my bike this week after 3 weeks off.
It has gone badly. Very, very badly! My legs are dreadful compared to where they were and I experienced my first puncture in 3 years yesterday, necessitating a roadside tube change. Lucky I had a spare tube, as my repair kit is shocking. Does anyone have a recommendation for a reliable one?
Without having any 5800 shifters to hand, alas, I can't say for sure, but if you look on the outer edge of the shifter there is probably a groove in the plastic and if you pull the rubber housing away at that point there is an Allen key in there which tightens the clip that holds the shifter to the bar.
Hey mate, nice name
3 weeks off is quite a break which is probably why you're suffering. You'll recover well though but I imagine it'll take a couple of rides to get your body back 'into the swing of things'.
I'm carrying The Park Tools vp1 patch kit, a set of Park Tools TL1c levers (after I broke some of my cheapy ones, currently carrying 5 levers!) along with 1 innertube and a frame mounted pump. Ideally I'd change tube in the case of a puncture, in the case of a double I'd have to repair one of them at the roadside. I've only had 3 punctures in ~2000 commuting miles, 1 caused by me (ie not actually out on the road). I also carry some latex gloves (stops dirty fingers!) and electrical tape (can be like an extra pair of hands when refitting a stubbon tyre) along with many tools (probably more than required but for what it takes I'd rather have them!). If my saddlebag was larger I'd carry the same but with 2 tubes!
Grudas if you're lurking do you (or someone else) have a link to the pads you're using from Amazon? Gonna grab me some!
£499 power meter.
Not sure if it's any good or not but even if it's garbage it'll still help drive prices down from other manufacturers! £500 is something I can almost justify to myself...
Yep, it's £700 for one that does both legs.
I've read a lot of mixed arguments about the whole two leg vs one leg measurement for PMs. The general belief seemed to be that most people don't have such bad muscle imbalances that measuring both legs isn't really required and for the average person it's probably worth saving the extra cash.
Those with PMs, any thoughts?
I would still probably use one with the exception of Stages, just because of the other issues they have.
For me, as long as the PM works and is consistent then it doesn't really matter, its still going to get you to the end result. Sure comparison to other riders is nice, but its not what I have a PM for. Its much the same as trainer road and a turbo, sure the actual power figure is likely a fair bit off, but as long as its consistently off then you're fine to be able to track progress with it. It's still going to give you your training zones, and allow you to train specifically, while allowing you to track improvements.
As an aside I've always carried a bit of an imbalance in that my usual L/R balance is something like 48/52 anyway.
I find that when out for a casual ride, my left side is stronger but any TT riding I'm almost 50/50 bang on, I believe this is down to me playing football in my younger years, and being predominantly right footed, meaning my left leg done all the standing power. (or so my bikefit bloke told me)
The extra stats of the vectors certainly help as you can focus on where your muscle power is coming down on the pedal stroke, where your foot is putting the power down in the pedal etc, which in theory should help me ever so finely tune my cleats so they're in the most optimum position and work on that based upon this data.
https://connect.garmin.com/modern/activity/748311538
Garmin trace with full stats.
I swear I bought a bulk load of inner tubes, but I can't seem to find them anywhere...
On a downhill before a chicane (pit entry at the race track) rider two infront seemed to sit up. Guy infront goes round him on the left and I on the right. He starts to move over onto me as I'm almost past so I shout. Unfortunately there were very small cones on the edge off the tarmac here which you couldn't see unless you were at the front and I hit one with my shoe. No harm done I thought until I lean into the chicane at 45kmh.
A quick 180 or more degree spin as the rear tyre blows out throws me off the back of the bike, and I use my cleats as skates to go backwards along the tarmac standing up holding the bike. Somehow the whole pack misses me and I end up stood on the grass at the pit entry.
A spoke has pulled through the carbon zipp 303 rim, my chains off, my cleats and shoe heels are non existent, my rear tyres blown and my hr is off the chart.
Come away with $1000 repair bill and just some tyre burns to one shin....
Cleats & shoe heels gone!
And a bit of tyre burn...
If I were carrying 2 I'd probably look to have 5 or so at home!
Definitely interesting to see the stats. How do you interpret the extra bits and use them to improve your riding?
The Garmin peddles aren't an option for me as I'm sticking with SPDs for the foreseeable future. Still interesting though.
