- 21 Jul 2005
- Officially least sunny location -Ronskistats
I await for some real posts of guys playing the game with similar specs - chiefly FX cpus and the fps that accompany the settings.
Yeah, saw that a few days ago and even posted it in the GTAV thread in the PC games section. I don't expect to be running at max settings, but I want to find out roughly how low the game will need to be turned down to play it at 60fps most of the time. A mix of medium-high would be just fine, but a lot of low settings would not.
its around 40fps - 60fps, i can tell when it drops to 40fps its not as smooth, guess an intel I7 would sort this, but with skylake around the corner best to hold out now,
A decent sized patch was installed which was making me think it was an issue with game, rather than my hardware and/or drivers.
AMD’s chips hit a minimum frame rate of 30 FPS, compared with 37 FPS for the Core i7-4790K. That gap is significant — Intel’s high-end cores are hitting a 23% higher frame rate. That said, these gaps can be reduced by lowering visual quality from Max to something a bit less strenuous — many of the Advanced graphics features and post-processing effects in GTA V incur a heavy performance hit.
The bottom line is this: While CPU brand matters in GTA V, it’s not the major factor. Every chip, save for the Intel Pentium G3258, can run the game. Low-end AMD owners may have to put up with a significant performance hit, while most users with AMD Athlon 760K-class processors likely aren’t trying to run GTA V in the first place.
I have
8320 4.4 ghz 16gb 1866 8gb 290x Asus 990 - plays great at 1080p
4820k 4.3 ghz 32gb 2133 3gb 780ti RIVE - plays great at 1440p
Monitor makes the most difference imho!
