Time to replace HX 520 but with what?
That's why I was originally considering the G2 because of the 10 year warranty.
Okay it'll be either the 650W GS or the 650W G1. The 10 year warranty is very appealing but I'm confident the GS could last as long. Though of course it could not.
Toss a coin, it's your decision :D
If it's a good PSU then it'll likely last more than 5 years - I'd prefer the Seasonic based GS as it'll be superior in terms of components used etc but this is your decision at the end of the day
Your HX has lasted this long and that had a 5yr warranty.
True enough mate, it's hard to believe considering all the stress it's had over the years.
I think that'll be what I go for in the end but there's massive peace of mind with a 10 year warranty.
I am currently on an Antec High Current Platinum 1000W.
But ive had FSP (Aurum 750), Corsair (HX620) and some others i cant remember before.
Considering the 975BE is 125W TDP, and the EVGA GTX770 SOC is 230W, thats 355W combined without the rest of the rig. The SuperFlower 750W will be most efficient at around 340W - 420W, so methinks it would be the best unit to go for.
That's peak power though, which will only be when I'm gaming.
Woot! Order placed!
I went for the EVGA G2 750W, one of the original PSU's I was after. The 10 year warranty and future proofing was too good to miss, even if it doesn't get fully utilized.
It's a SuperFlower OEM so stulid you should be 50% satisfied lol. I'm just glad it's over.
Personally I would have gone SLI one day (it's a lifetime ambition xD) and I would have gone for the G2 750W, yes, or the 750W SuperFlower HX at that price, but in your case probably would have stuck with the 550W GS
Tis a good decision whatever you pick though, they are all good PSUs
Yeah I'm a bit concerned I've gone OTT, but I'd rather that than underestimating power needs. I definitely don't plan on going SLI or Crossfire, but I do want a singular high end card along with a CPU upgrade, whenever that may be.
