Caporegime
- 12 Mar 2009
I think I saw you post that you have a wireless headset? Would you mind sharing which one?
Thanks
Yeah sure, it's a Corsair Vengeance 2100.
Thanks
Was waiting a few days to see if this is the real deal in terms of performance before I double dip and it seems to be the case!
Is it worth punting (another) 40 quid at this or should I just hold out for a little longer for a discount?![]()
Snapmatic you want to use. Or MSI Afterburner/Fraps and it will go into the folder wherever you have it set.
Getting nothing but crashes after doing thisI'm on Windows 8.1 64. Tried some of the fixes here: http://reshade.me/forum/troubleshooting/498-gta-v-crashes-with-reshade-17-1-sweetfx?start=6
Working fine with me Win 7 on 7950.
Yeah sure, it's a Corsair Vengeance 2100.![]()
I'm on the lookout for a wireless one as I have been playing GTA on my projector so sitting on the sofa and cba with long cables floating about.You should only have one **AA on according to TotalBiscuit as they cancel eachother out but still use the performance.
Relevant now that PC GTA V is out:
http://i.imgur.com/EdWPCTu.jpg[/IMG
:D[/QUOTE]
:D always the same with each generation!
Does it add much to the game, what about performance hit? I'm on Win 7 with 7950 too, the game is running great though and dont really want to mess it up ha
Right!!!!
Fresh install of Windows - check!
All drivers etc installed - check!
Steam installed - check!
Let the download commence yet again! *goes to pray in a corner that no more BSOD's happen*
Stoner81.
Just over one day left of my download- along with patches and work, assuming all goes to plan, realistically I should be able to play on Wednesday
A little concerned about my SSD though - by the time the game has downloaded, and Steam has allocated space for the game, I should have about 70Gb left. Considering this is still the preload edition, I hope that it is enough. Might have to move some files around to achieve the final install though?
