***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Never occured to me to try that, i just put one of my standard protank 2 coils in and it fits perfectly. However the boxmod shows no coil present so I'm guessing you would have to use a different kanger coil??
does your mod not have a floating 510? if not you may have to lift the pin up slight (be gentle) I think the areo head pins are slightly longer. Also you need another rubber ring thing on the inside of the tube itself to stop it from leaking. that should push the head down and make better connection.
ok its going to have to be the box mod
is the Eleaf 30w at £32 a good buy? http://www.vapeescape.co.uk/MODS-Advanced/Eleaf-IStick-Mini-IStick/Eleaf-IStick-Bending-Adapter.Html that adapter looks good as well
Yes, I use vapescape all the time. The bending adapter is a bag of ****, I have one, it causes voltage drop and was an after market fix for the bad connectors on the istick 20w. It also wont fit on the 30w mod. :)
Thanks, will give that a go and report back.
Heads up... Provapes have Silicone cases for the istick 20/30/50 watts, Cloupor mini and the ipv mini in stock at the moment.
EDIT:
Just seen that kanger have a new airflow control for their subtanks, they must have heard me slating them for MTL hits.. lol
The single hole is much smaller, you may be able to get one for your full size subtank and make it into a MTL tank.
https://www.facebook.com/Kangertech/posts/1558264737771989
Just seen this....
How easy would it be for Joyetech/eleaf to make a dual 18650 mod with removable batteries!
Call me crazy, but I might get the heatvape invader mini.. 50w, single 18650, temperture control, shock proof and splash (water) proof. Ideal for nights out and I like the idea of vaping in the bath!
I have decided to go for the eleaf istick 30w and a kanger mini subtank. Would this be good, as this my first time getting somthingn proper rather than the daft little ones from the petrol station i go to lol. I havnt bought anything yet as i am waiting for payday and just want to make sure i am doing it right lol.
If there is anything else i need any help would be great and also where would be the best place to get it from.
Cheers
Cheers
If you are getting the subtank, make sure it's the new version with the dual airflow channels. It's design for mouth to lung too, else you might end up with a tank you can't use. :)
Ok guys last question on batteries now :-)
Eleaf istick 20w for 20£ brand new or a ipv mini with a battery for the same price but used? guy said he hasn't used it long and I can put a new battery in it.
Went on a spree this morning.
Sub Tank Mini
IPV2 carbon wrap
30ml Blackbeards Delight from isle of custard
30ml Apple Custard from isle of custard
30ml Heisenberg Concentrate
200ml VPG 6mg 50/50
If the wife see's my vape haul I'm dead. Luckily getting it all delivered to work! :D
there's very few people I would trust when it comes to batteries, they are considered as a consumable item and may have been poorly looked after with there's loads of fakes out there. Free battery to me is just as appealing as the term free juice and offering me a second hand battery; is like offering me second hand toilet paper! I would rather them knock a discount off than give me a battery, Of course this does depend on the vendor.
The istick 30w is a much better device than the istick 20w, IMHO worth the extra 12 pounds.
Get the 30w, save yourself buying another device in X amount of months.
I guarantee if you spend abit more money you will be on here saying " why didnt i do this sooner" as pretty much everyone else does when they make the jump up
I got to agree.
The jumps are sooo worth it.
That being said, I was vaping with a ego style device for 8 hours before I made the jump to a Vamo. It was around 8 months later I made the jump to a DNA device, then around another 5 months before mechs became the norm. Although I had mechs before the DNA, I didn't "get" them until later.
Now I find sub ohming really pleasing. But it would probably have ripped my throat apart had I went full belt into it from the start. Now I find anything less than an ohm to be like sucking air.
I had a MVP v2 as a back up for a long time though, but I found I was never building coils high enough to use it. So recently bought a istick 50w and a vapourflask DNA40 (clone) to use as backup devices.
On another note, any decent "pipe" style mods out there? Quite fancy rocking the flat cap & brandy look.
I got to agree.
Snip....
There's a lime lights one going at safer vapers at the moment, I quite fancy a pipe mod myself but the size of the things are really off putting.
Sub Tank Mini
IPV2 carbon wrap
200ml VPG 6mg 50/50
Out of interest how much of the concentrate do you add per mix? 10%?
I am just delving into self mixing and the heisenburg use to be a daily for me.
Looking at the vampire site is it 9.99 per 30ml? :D
I got to agree.
Snip
Love my pipe,
You'll often find me lording it up in wingback chair, smoking jacket, with a brandy parping like a Sir,:D
Status
