I just searched the book name on Google images.
Great tip! Thanks
Riding to Cheltenham in the morning. Technically the longest ride I'll have done though given how flat it should be I don't think it will be the hardest.
Should be fun anyhow.
Hope you're getting on ok mate, few spots of rain and a shower or two here in Hereford but nothing major, winds are currently calm but were worse this morning!
How far is that?
Got my new wheels from Halfords, they look lovely but there's not many spokes so might have to take a bit more care around potholes
They look nice! Enjoy!
From the great man himself well chuffed!!
Flog it on eBay for a tidy profit, or maybe after he smashes the hour record?
Did some basic maintenance this morning before the rain, complete clean, changed chainring bolts and stripped down mudguards to check some rubbing as I've noticed a mark on one of my tyre sidewalls. Couldn't quite figure out the marking until I realised how buckled my wheels are! They're terrible! Easily 5-6 mm lateral movement, maybe more!
As I've noticed my ride feeling harsher I was sure I needed to tension some spokes so started to tighten them on my rear and now it's even further out of true
I started off with half turns but some of the spokes were so loose they needed 4-5 complete turns to get anywhere near tight! Now I've tightened them all the wheel is so buckled it touches the brake blocks and frame!
Got rained off so I'm now searching for advice on how to 'start again' with my spoke tensioning, I'm guessing the first step is to remove all tension from all the spokes? As for a 'spoke tension tool' I only see the
park-tools TM-1 mentioned, at £50 I think I'd rather take my wheel somewhere or buy a new set! Any other options for testing the tension?
TLDR; I've done my spokes too tight and buckled my wheel, how do I sort?
