Best thing I can recomend is if you are not getting a refund/decent replacement is try the Skynet BIOS. However if you do this make sure to backup you'r current bios using GPU-Z.If someone would care to supply me with another gaming PC I'll happily do so. But seen as all the problems go away as if by magic when I fit one of my spare (old) cards, and clearly OcUK and Gigabyte are finding the cards faulty on test as well I'll stick with my current thoughts for the time being. I really cant think of anything left to test on my system that hasn't been tested to death already.
And no need to switch to the wrong side of the tracks, I just need a card from a manufacturer that has a QA process, but I can't afford to buy an alternative until next year at the earliest.
I'm sure if these cards were only running at reference speeds they'd be totally fine. There just seems to be no cherry picking of chips to make the overclocked cards by gigabyte, just throw an oc bios on and off it goes.
Maybe I'm just being very unlucky, who knows?
It's up to you.
I think the problem with most of these cards is the cooler and stock 1.75V not being enough for the OC and the cooler.
