Think I have seen elsewhere they need 80%?
Saw 40% bandied about on this other place as the bare min too, not looking good.![]()
Would be nice to know what exactly to expect from Zen+, the angle of ascent seems to indicate 10-15% extra only.
In IPC, yeah they're a good 80% behind HW.
40% is a big improvement and gets them at around SB IPC. It's a step in the right direction, it's the bare minimum needed
I wonder though, will AMD Reps start using their own CPUs instead of Intel after Zen launch?![]()
I have faith in Jim Keller.
You do know what IPC is?
The number of instructions per second and floating point operations per second for a processor can be derived by multiplying the instructions per cycle and the clock speed (measured in cycles per second or Hertz) of the processor in question. The number of instructions per second is an approximate indicator of the likely performance of the processor.
The number of instructions executed per clock is not a constant for a given processor; it depends on how the particular software being run interacts with the processor, and indeed the entire machine, particularly the memory hierarchy. However, certain processor features tend to lead to designs that have higher-than-average IPC values; the presence of multiple arithmetic logic units (an ALU is a processor subsystem that can perform elementary arithmetic and logical operations), and short pipelines. When comparing different instruction sets, a simpler instruction set may lead to a higher IPC figure than an implementation of a more complex instruction set using the same chip technology; however, the more complex instruction set may be able to achieve more useful work with fewer instructions.
Instructions per clock cycle, piledriver is about 40% behind Haswell.
Haswell is about 10 to 15% better than sb
/dreams
So basically an AMD chip that goes head to head with the 5960x for a much cheaper price.......
If that happened I would be sooooooo happy
/dreams
your having a laugh, Haswell is about 30 to 40% faster than piledriver.
The proposed Zen looks to be very good, but I'll put up my reservations on price. AMD don't price the way they do because they're a good company, it's because they're in a position of weakness.
