- 2 May 2011
- Woking
Morning all,
I'm in the process of buying a house off plan and I'm asking them to install ethernet cabling around the house, but this is something I have no experience of and could do with some advice.
The plan is to have a central media server, and then have a raspberry pi in both the sitting room and the master bedroom, and then there will be a PC in the spare bedroom, all of which I'd like to have wired. I was planning to put the server in the cupboard under the stairs, and also have the router in here (the house is basically 2 up 2 down, so wifi reception won't be a problem).
I'm wondering now whether having the server under the stairs is actually a good idea...will it be a pain to then work on it if needed? ie will I have to go and sit under the stairs with a monitor etc to do anything to it?!
I was then planning to have all the ethernet cables coming into the cupboard under the stairs with a network switch (can anyone recommend me a reasonably priced one for probably 4 connections?) and then have that connected into the Raspberry Pi.
Am I going about this completely wrong, though? Do I just need all the devices connecting into my router, and then choose one to be the server?
Also, I have to basically put together the specification for the builder of what I need, so at the moment this is what I think I want..:
I think that's it. I've probably made this way too complicated and confusing, so if anyone has a decent guide that they could recommend that would be great.
Thanks in advance,
dirtychinchilla
- CAT6 RJ45 wall socket
- CAT6 cabling throughout (could someone recommend me a decent type?)
- Network switch under the stairs (again, I'd appreciate a recommendation)
Thanks in advance,
dirtychinchilla
