** SAMSUNG: WARP SPEED CAPTAIN, ENGAGE!!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The new M.2 PCI-E SSD's are getting extremely fast as long as you have a motherboard to support the technology. Now in stock at OcUK are the new SM951 M.2 SSD's:
Samsung SM951 128GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV128HDGM-00000) @ £89.99 inc VAT
The SM951 boasts outstanding performance, supporting both PCIe 3.0 and PCIe 2.0 interfaces. They can read and write sequentially at 1,600 MB/s (megabytes per second) and 1,350 MB/s respectively based on PCIe 2.0. This performance level is approximately three times faster than that of the latest SSD with a SATA interface and about 30 percent faster than that of the Samsung XP941, its predecessor. In addition, the new SSD's random read and write speeds reach up to 130,000 and 85,000 IOPS (inputs / outputs per second) respectively.
For ultra-slim notebooks and workstations wanting to adopt the PCIe 3.0 interface, the SM951 can read and write sequentially at 2,150 MB/s and 1,550 MB/s respectively, which would provide approximately four times faster sequential reading performance compared to current SATA SSDs. With a PCIe 3.0 interface, the drive achieves substantially higher energy efficiency, requiring only about 450 MB/s per watt for sequential reading and 250 MB/s per watt for sequential writing, which translates into a more than 50 percent improvement in performance per watt over that of the XP941 SSD.
In addition, the SM951 is the first SSD to adopt the L1.2 low power standby mode (which allows all high-speed circuits to be turned off when a PC is sleeping or in hibernation) as defined by PCI-SIG (the PCIe standards body). By embracing the L1.2 level of standby operation, the SM951's power consumption is drastically reduced – to under 2mW, about a 97 percent decrease from the 50mW consumed using a L1 state.
Samsung's SM951 comes in the M.2 form factor (80 mm x 22 mm), which is only about one seventh the size of a 2.5" SSD. Also, it weighs approximately six grammes. The drive's compactness is well suited for most notebook PC designs, freeing up space for other components including the battery. The SM951 lineup consists of 512, 256 and 128 GB SSDs.
PLease Note. Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot
- MLC NAND
- Read Speed: 2000MB/s
- Write Speed: 600MB/s
- IOPS: 90k/70k
- Warranty: 2yr
Only £89.99 inc VAT.
ORDER NOW
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV256HDGL-00000) @ £155.99 inc VAT
PLease Note.</b> Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- MLC NAND
- Read Speed: 2150MB/s
- Write Speed: 1200MB/s
- IOPS: 90k/70k
- Warranty: 2yr
Only £155.99 inc VAT.
ORDER NOW
Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV512HDGL-00000) @ £299.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1500MB/s
- IOPS: 90k/70k
- Warranty: 2yr
Only £299.99 inc VAT.
ORDER NOW
SSD's getting insanely fast!!!!
Because I am a bit of a noob, can I ask which interfaces are supported here?
It says on the product:
So just to confirm, it doe not have to be an M2 PCI-E slot, just your bog-standard PCI-E slot?
Jeez I didn't even know these things existed!
No way my ancient hardware will be able to run this :p
Its basically a pcie SSD which in many forms has been around for a long time but now it has a dedicated mini-slot called m.2
At the same time it still takes up pcie lanes despite not being in a normal pcie slot so this can affect multi-gpu setups as there's only so many lanes to go around.
The average user with 1 gpu is not going to care.
I have one of these and they are FAST !!!!!
will you also be stocking the pci x4 pci-e Card with a heatsink as they throttle if not actively cooled.
if you copy large files they 10 Gb + GTA 5 for example they thermal throttle
104 degrees
https://www.youtube.com/watch?v=3hhdWwvh5kI
link to vid with thermal cam on them
they need cooling or speeds drop to 70mbs
