Man of Honour
- 16 May 2005
- Manchester
I prefer to sit whilst hill climbing unless it's a very short steep bump. I try to stick to 90ish cadence for it, at least until I run out of gears.
Surely ave speed over a set course/ distance is a basic indication of progression?
but I think it may be off for a few weeks after tonight, check my latest thread haha.
A lethargic week after an active week last week. Cycled to work this morning and got passed again by this flattop van of a landscaping firm. He passes me in exactly the same point, every day, and the passenger always leans out the window and shouts "Put some ******* lights on!", be it broad daylight or the murky gloom of the morning (in which case, I do actually have lights on!).
Looking at ANT+ USB dongles for TrainerRoad to use with either my old Windows Laptop (which I might just leave in the garage) or my MBP.
I've used a suunto one which is now with Roady. Absolutely fine. No difference between that and the garmin tbh.
Do you already have an Ant+ speed/cad sensor on your bike btw? If not, the cheap Decathlon one (£16 iirc) is decent enough for turbo use.
It's good but I assume it's similar to the new Garmin magnet-less sensors - slightly slower to react to changes in cadence.
I've decided to enter the shameful world of Tri/multi-sport by entering my first Olympic distance triathlon.
I'm fundraising in memory of my brother for the event and would appreciate any monies you wealthy cyclists can spare.
http://uk.virginmoneygiving.com/liamreilly
Shamrock's Donation Page said:The triathlon consists of a 1.5km swim, 40km cycle and 10km run. I consider myself a fairly strong cyclist, a mediocre runner and a terrible swimmer!
Gatorskin tubs don't seem to have the bad rep that the clinchers have. Not sure why, I don't know what the differences in construction or tread are.Different wheels and tyres each time. Having been cycling properly for about 3 years now I could count the number of punctures I'd had on the round almost on one hand. Until this year. Not sure if thats just because I'm doing way more miles though.
Will do some investigation on gatorskin tubs, if not will just get conti competitions again. If they puncture then I'm ditching the tubs for good.
Sorry to hear about your brother, in fact sorry that I may have missed it if you mentioned him before. Good luck with the tri. London is a good oneI've decided to enter the shameful world of Tri/multi-sport by entering my first Olympic distance triathlon.
Strava says otherwise.
I'm a mediocre runner and I do 10km at 5.08/km, not the 4.26/km pace that you call a 'steady' 10km.
Sorry to hear about your brother, in fact sorry that I may have missed it if you mentioned him before. Good luck with the tri. London is a good one![]()
Oh yeah I need you guys to sponsor me too, to ride 425 miles over 4 days in July.
https://www.justgiving.com/David-Cross10
I admit it's basically a jolly but work pressure to raise money means I have to ask.
I'm willing to get legs waxed, head shaved etc if it helps.
My triathlon has come round so quick, it's two weeks on Sunday. I'm still a shocking swimmer!
Making a new post to keep things tidy...
My 'home maintenance' is ongoing with a new experience last night - removing cranks from BB, greasing & refitting!
But first a couple of pics from a few days ago, removed the KMC X11L chain my Giant Defy 1 2015 came with after just over 900 miles. The chain tool told me to!
Replaced with a SRAM X1 11 Speed Chain from CRC (website down so can't link) £19 after grudas and others reporting high mileage in all weathers. Looks superb and shifting is now crisp and smooth again!
My next process while trying to eliminate 'clicks' (and the occasional creak) I've had was to take a look at my BB and regrease it. Probably not required on a bike less than 6 months old and <1000 miles but I wanted to eliminate it from my troubleshooting and take a look at it myself! I removed my non-drive side crank (have done before for cleaning) and after asking a friend (and reading/watching online) I gave the spindle a bit of a tap while pulling the drive-side crank spider... It came out easily (with a bit of wiggling) and I was presented with this:
As things were not as bad as I was expecting I gave it all good clean and wipe, then regreased where I thought needed:
Refitted everything and after the commute in this morning (still got a sore & tender achilles) it's much better... I still do have a click when putting power down, it's not as pronounced as yesterday and I think it's 'higher up'. Next I'll be regreasing my headset and refitting. I've taken it apart and cleaned it before, can post pictures if anyone wants!![]()
check your saddle rails ! trust me on that, I've had clicking for WEEKS, couldn't find what it was.. felt like it was coming from BB/chainset but it was saddle rails??! dropped a thin layer on the rails and put it all together.. bam silent?! magic beans ffs.
It may actually be the fit between the press fit BB and the frame that is giving the click. BB30 and press fit stuff is terrible for it.
Check your mech hanger bolt + bottle cage bolts too.
I've done the 'hold the saddle and force it around' trick and it was silent. Tightened up the saddle bolt a week or two ago and it's still tight. I get the click when stood climbing which I wouldn't think could then come from the saddle?
